report setup in chemstation
Is there an easy way to set up an extended report to show plate count? I currently have a report method in short form that I need to convert to extended so I can include a plate count column. Where can I get help setting this up?
If you change the report style from short to extended it will include the plate count. Just make sure your components are identified.
We cannot solve our problems with the same thinking we used when we created them. -Einstein
Yes there is. In Data Analysis go to the menu bar "Report", choose the "Specify Report" from the fall-down menu, and then in the "Specify Report" window, choose "Performance" for "Report Style".
Best regards
Users browsing this forum: John Guajardo and 9 guests
