MSD fault
I have a 5977 MSD. The MSD has a dec6144hex1800 fault code.
Somebody can help?
Somebody can help?
Hello, the first thing you should do is identify the error. For that you are placed in the control software of the equipment (Masshunter control of the equipment) and you look for the VIEW menu and you enter it. Then you look for the STATUS menu and when you click there, look for the MS Error Codes submenu ... and Enter the Hex or Dec number. The screen should turn black and the error title should appear at the top.
I wait your response.
Henry
