Range calibration curve EPA 8270D
On the one I have a little curiosity, I would like to know what the range that you used to calibrate the metdo EPA 8270D for PAH?
because I build from 0.1 ppm to 8 ppm and add the internal standard to 4 ppm.
This is because I have an abundance of the standard of 1 million!
Thank you
Buon Natale
Natale,
Your calibration range is a bit on the narrow side (80X) but not that far off; what I see is labs calibrating from around 10PPM to 120PPM or 160PPM.
You're calibrating lower than many, but I would presume that you have need to report as low as you are calibrating.
Greg
In total there are 20 users online :: 2 registered, 0 hidden and 18 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot], Semrush [Bot] and 18 guests
