ChemStation error message
Has anybody ever seen this ChemStation error message ?
"Method not compatible with instrument ! Current method is not valid ! Please load valid method ! "
Thanks.
In technical lingo, it just means something is screwed up !
Examples:
Loading a corrupt method.
Loading a method created with Rev B software under Rev A.
Loading a method with wrong module parameters.
One more possible explaination. Corruption in ChemStation or the Operating System software can cause read/load problems.
Thank you for your reply.
I can foreclose the first and the second choice for one reason: I am unable to load the default method, which cannot be changed.
What does it mean to load a method with wrong module parameters ?
Thanks.
I allready know where was the problem.
I change the regional settings in windows.
well, that´s me :roll:
In total there are 14 users online :: 0 registered, 0 hidden and 14 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 14 guests
