negative peak before the analyte peak
Posted: Thu Dec 04, 2008 6:39 pm
Hello
I am working on the detection of a compound in a LC-MS/MS (HPLC1200 - 6410 Agilent MS).
I tested different kind of columns (C18, C8, phenyl) and mobile phases (acetonitrile, methanol, formic acid, ammonium formiate) and I always have a depression before the analyte peak; this depression makes the desired limit of quantitation be deformed. It is like a negative peak, and when the line is going up the peak appears and it seems that the start point of the peak is in the depression of this negative peak.I had already make this study in API 2000 + HPLC 1100 equipment and this does not happen.
Does anybody has an idea ?? I tought it could be something in the HPLC.
Thank you in advance.
Maristela
Maristela
