HP6890/Chemstation error "Front inlet pulse not active&
Posted: Thu Dec 18, 2008 12:44 am
I switched to a splitless pressure pulse inlet and after chemstation loaded method to GC, this error message appeared. When I ran the method, the error cleared. How do I check the GC to make sure the pressure pulse is being used. The display on he GC inlet showed splitless pulse pressure and the parameters of the method is identical to the GC's. Thanks.
