Need help immediatly
Hellow,
I need immediate help for analysis of Ammonia Gas along with Monomethyl amine 40% Aq, Solution and Dimethyl amine it is alos 40% Aqueous solution. I am using TCD detector and DB-I column of 15meter and 0.53mm ID. Please suggest me that how I can analyse these three [Ammonia gas , Aqueous solution of MMA and Aqueous solution of DMA]
I have only TCD and FID detecor.
CAn I use Varian's CP-Volamine column on TCD or FID for this. Please suggest me as soon as possible.
Praveen
Looking at Scanview, it appears that the CP-Volamines column is what you want to look into. 60m x 0.32mm
TCD Detector
Users browsing this forum: Google [Bot] and 5 guests
