SIMDIS PTV operating pressure/flow ?
Posted: Wed Aug 28, 2019 1:28 pm
Hi, I am currently creating a method based of of ASTM D7169.
I am using a PTV inlet.
my column diameters are as follows length 5M internal diameter 0.55mm and a film thickness of 0.15µm. my current column flow is 20ml/min He ( constant flow)
can someone please recommend flow rate starting conditions for the PTV.
should it be higher or lower than the column flow ?
Thanks in advance.
Chemiger
Thanks in advance.
Chemiger
