thanks
problem resolved
Even if there is an intrinsic difference in noise, it may not be a problem in practice. My suggestion is to carefully consider the settings for the sampling rate / detector time constant, and - most of all - to try it out after this has been optimized. You can easily get a significant noise reduction with such tricks.
Users browsing this forum: Semrush [Bot] and 8 guests
