RRF
RRF
i have confusion in detemination of RRF in my substance which is contain salt (rizatriptan benzoate). When i determine the RRF generaly i use the potency of drug for corrected mass but in this case my substance contain approx 30 percent benzoic acid as a salt form. So which potncy should i consider 70 percent or 100 percent?
I mean to say the 30 percent weight correcton should i applied?
Response factors (and relative response factors) should always be calculated with respect to the actual amount of your analyte present.
In total there are 16 users online :: 2 registered, 0 hidden and 14 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Semrush [Bot] and 14 guests
