DIY Suppressor in IC
For routine anion analysis using conductivity, what is an easy way to accomplish post-column suppression?
Do you mean easy or cheap (they're not the same).
Easiest is to buy a suppresor unit from Metrohm or Thermo.
Cheapest is to slap a cation exchange cartidge in the H+ form in line between the column and the detector, but you have to hope it won't add too much dead volume, and it will take a bit of effort to figure out how long you can go without regenerating.
Users browsing this forum: Google [Bot] and 12 guests
