DIY Suppressor in IC
For routine anion analysis using conductivity, what is an easy way to accomplish post-column suppression?
Do you mean easy or cheap (they're not the same).
Easiest is to buy a suppresor unit from Metrohm or Thermo.
Cheapest is to slap a cation exchange cartidge in the H+ form in line between the column and the detector, but you have to hope it won't add too much dead volume, and it will take a bit of effort to figure out how long you can go without regenerating.
In total there are 23 users online :: 2 registered, 0 hidden and 21 guests (based on users active over the past 5 minutes)
Users browsing this forum: John Guajardo, Semrush [Bot] and 21 guests
