QuicK QUESTION-----HOW IS HPLC USED TO TEST FOR SICKLE CELL
IM DOING RESEARCH ON SICKLE CELL AND THE HPLC TEST CAME UP. I JUST WANTED TO KNOW WHAT IT IS AND HOW IT IS PERFORMED.
THANKYOU, KEL
kmata,
This test is based on cation-exchange HPLC (a technique for separating molecules based on the distribution and quantity of positively charged sites on the surface of the molecule). Patients with sickle cell anemia have one of several variants of hemoglobin that are different from hemoglobin found in normal patients. Since these variants are slightly different in shape as well as the magnitude of positive charge under a defined set of conditions, these variants can be separated and detected based on the rate at which they pass through a cation exchange column. Bio-Rad (http://bio-rad.com) sells equipment and analysis kits for this application. You might find more about this application there.
In total there are 17 users online :: 0 registered, 0 hidden and 17 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 17 guests
