Column thermostat?
Anyone know a US supplier for a stand-alone column thermostat (~5°C to ~80°C) that can be qualified and doesn't take up much space?
I'm using an Agilent 1100. Agilent's column thermostat compartments are ~3k - without a valve assembly! That amount of money isn't in the budget right now and a bit overkill for my needs anyway. I remember using a stand-alone thermostatted compartment at a previous employer with Shimadzu systems, but can't recall the brand (wasn't Shimadzu).
Thanks in advance,
t
just looking around...
You can probably find what you need from any of the major consumables suppliers. Here's one that I know of:
http://www.analytical-sales.com/Heaters.html
Dear tnt_tx
Please have a look on these:
http://www.metrohmusa.com/products/prod ... HPLIDX=367
Dr. Markus Laeubli
Manager Marketing Support IC
(retired)
Metrohm AG
9101 Herisau
Switzerland
We got one for better than free a few years ago from Grace Alltech, still in its package. It was less expensive to buy their conductivity detector and a column thermostat together than the conductivity detector only. Yes, you read that correctly.
Thank you all for your feedback. I've been looking into suggestions and have more info to track down.
If only I needed a conductivity detector :wink:
t
I have big temperature issues with my ion chromatograph (Metrohm) , and I went on the hunt for a column heater/chiller. I discovered that Restek and Phenomenex have heater/chillers that work for both HPLC and ion chromatography. As a matter of fact, I am going to be trying out the Restek one for a week this summer with a loaner to make sure it will take care of the problem. Also, Sigma-Aldrich carries the Jetstream Plus Column Heater/Cooler. FYI, all three seem to be reasonably priced. :D
In total there are 17 users online :: 1 registered, 0 hidden and 16 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot] and 16 guests
