Data Export from HPLC
Hi Dear Experts!
I am new with HPLC and have a question. The software that I am using is EZChrome Elite 3.3.2. SP2. I have already run my samples and have the raw data some in dat format and some in met format (I dont know why they are in two different formats).
I know that I can export data to excel through Method, Advanced, Export Enabled. But apparently it works when you already set this setting before running the samples.
How can I export data after the run? How can I convert dat and met format to excel format?
Any advice is truly appreciated.
Mahnaz
If you open the file in EZChrome, you should be able to export it as text, if nothing else. They may have the feature under save, save as, or export. Exporting post-run is a feature of all chromatography software I've encountered.
You need to reprocess. Either the single data file (if you need only that one) or the whole analysis sequence.
If I recall correctly, that would be Data>Reprocess (for the single file) or right-click in the sequence>Reprocess (for the whole sequence).
