integration report agilent 1200
hi,
when I choose integration report and it is printed out, always the name of each the sample(injection) looks like has been cut in the half; additionally, that 'name' hasnever looked like 'the name' which I put in the sequence table;
there is only the first name (in the top of fird page of integration report) of the sample from sequence table
can I change it (the best would be he same name for sample/injection as in the sequence)?
An example would help. Can you post more information, or a scan?
Also, check your printer setup. You may have to re-install the printer driver.
Merlin K. L. Bicking, Ph.D.
ACCTA, Inc.
