Repeatability issue
Hi all,
I'm running a GC system testing: Methanol, dichloromethane, o-xylene, ethyl acetate and acetone.
I'm currently validating the method and the %RSD for all solvents was allways not more then 2.0%
In the last sequence there was a strange problem were the %RSD for only methanol and o-xylene was very high (about 16%)
What could cause repeatability issue for only these solvents?
I'm using a headspace sampler with a gas tight syringe
Column: DB-624 30m x 0.32mm x 1.8um
Anyone?
I don't see a pattern with regard to MW or volatility - it might give others some ideas if a matrix was provided - what is the matrix that is being tested for with regard to these chemicals?
We need to know a lot more about what you are doing and how you are doing it. The nore you don't tell us the more we can't help you.
In total there are 33 users online :: 1 registered, 0 hidden and 32 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot] and 32 guests
