Looking for Gas Sampling Bags Manufacturer
I am looking for gas sampling bags/kit for nitrogen. Which brand would you recommend?
Terry
Terry,
I've always used tedlar gas sampling bags, which do a good job. available from loads of suppliers ( I use sigma aldrich), but i think they are manufactured by SKC, skcinc.com
Nick
Nick,
Thank you so much. It is very helpful.
Terry
You can also use GL sciences Tedlar bags.
They come in Tedlar, aluminated.
Many different kind of connection possebilaties.
You can contact GL sciences China
hi guys,
does anybody has a procedure (equipment setup, sample conditioning) for using Tedlar bag for Sulphur compounds on high vapor pressure liquids? if you could recommend a good vendor this will help me lots:)
thanks,
Tiffany,
Probably better to have this as it's own post. Have you considered a silico-coated Whitey bottle for this application.
Best regards,
AICMM
Tiffany,
Ooops, sorry, my fault. Had not gotten to your other post.
Best regards,
AICMM
