CG-FID of DOC
Perhaps before I start I should mention that I am an ecologist and no chemist, so would ask you patience in dealing with what are probably very simple questions.
I want to characterise DOC from marine macro algae. I have found a method for determining neutral sugars using GC-FID where the carbohydrates were converted to acetyl derivatives using what seems to an extremely complicate procedure (Handa and Yanagi Marine Biology 4 1969). I was wondering if GC-FID was the best way to go with this or if there are other alternatives ?
Any advice would be warmly welcomed.
Cheers
Adam
I have done alditol acetate derivatization of sugars for analysis from bacterial polysaccharides on a DB-5 30 M column (been a while for me - trying to remember the details). Basically, reduce with sodium borohydride, acetylate with acetic anhydride and 1-methyl imidazole. Add water to break down excess acetic anhydride the extract with 1,2-dichloroethane. We used myo-inositol as an internal standard. We had baseline resolution of all the sugars we could analyze at the time.
TMS-derivatization is another way to go, also.
David Slomczynski
Manager, Analytical Chemistry
Qteros, Inc.
dslomczynski@qteros.com
508-251-6288
In total there are 66 users online :: 0 registered, 0 hidden and 66 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 66 guests
