(a) Get current oven temperature
(b) Get current method oven programming details: mainly the initial temperature and the final temperature
(c) Possibly be able to read a method's oven programming details without loading it (like if it's the next in the sequence): again, mainly the initial temperature and the final temperature
It doesn't look like methods are loaded into registers or that there are any text files with the method's details within the .M folder (as in some other Chemstation versions).
Most of the RC.Net stuff seems to apply to LC as well. If anyone has access to the "available command set" one can use with SendModule$, please let me know as I was unable to find this anywhere.
Any ideas or help would be greatly appreciated.
Thanks!
