Definition of Dead Volume.
Hello. I'm a new member here. I was just reading through some materials on HPLC and I noticed that the term "Dead Volume" comes up quite a lot. I have done some internet research and not all of them give you a consistent definition.
The way I understand it is, a dead volume "maximum liquid volume" that can fill up the packed column. Is that right?
"dead volume" of column - Void volume of column - Vo
"dead volume" of CS (chromatography system) or "dead volume" Vm=Vo+Vinj.(injector)+Vcap.(communications)+Vc(detector cell)
If Vo(column)>>[Vo(injector)+Vo(communications inj.-col.-det.)+Vo(detector cell)]: Vo=Vm (approx.)
“Void volume (Vo) (of column): The total volume of mobile phase in the column; the remainder of the column is taken up by packing material. This volume can be determined by injecting an unretained substance(if Vm=Vo). R.E. Majors and P.W. Carr LC•GC 19 (2001), p. 124.
And, because many of us (myself included!) are somewhat sloppy about terminology, "void volume" is often used to refer to excess unswept volume (in a poorly assembled fitting, or at the head of a column where the bed has shrunk, for example). Those are usually evident from context.
Users browsing this forum: Bing [Bot] and 20 guests
