Missing Perspectives in OpenChrom
I'm working with Openchrom 1.3 for win_64 which I like very much but still, some issues need fixing:
    The perspective list is limited and needs to add/install others like: "Peak identification", "Denoising", "Manual Peak Detector", "CSD", "Chromatogram Peaks", "The OpenTyper" perspectives
      The installed perspectives do not change automatically
        How to get the peaks in the chromatogram labeled with the components name? How to edit the label text (change direction horizontal or vertical)?
          The "AMDIS Peak Detector" is installed properly in the preferences, but is not showing under the 'Chromatogram/peak detector'
            The same above for the "NIST identifier"
            Thank you in advance,
            M. Osman
            Version 1.3 is so largely outdated that you should consider https://www.openchrom.net/download a newer version. Major change to the interface is that you there is one main (chromatography) perspective called data analysis. You can switch additional windows on/off in the toolbar. The chemometric operations are done via the right-click menu on the chromatogram.
