No signal at negative mode
Dear All,
We are using an API2000 in our lab. Recently, we encountered a "weird" problem. During the tuning of a certain compound, we tried to do both positive and negative mode. Our signal with positive mode is very good. However, we didn't get a signal using the negative mode. Even running the solvent alone did not produce even a tiny bit of signal. Could you please advice what the probable cause could be? What should we do?
Appreciate any advice. Thanks!
I suggest you to conduct diognostic tests for quadrupoles if there is of your instrument. There may be problems in DC energy ramps of Q1 and Q3 for negative mod.
In total there are 30 users online :: 0 registered, 0 hidden and 30 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 30 guests
