Regarding protein hydrolysis
I have food sample which is in form of powder. I want to analyse the amino acid profile in this food sample. For protein hydrolysis via 6N HCL,
1. how can I create oxygen free environment in the reaction tube?
2. can I use reflux system for hydrolysis because it involves 110℃ for 20-24h?
1. how can I create oxygen free environment in the reaction tube? Use a Firestone valve, or similar device
2. can I use reflux system for hydrolysis because it involves 110℃ for 20-24h? No. Depending on the protein, you'll experience excessive degradation. Protein hydrolysis is usually done in a sealed tube.
which type of sealed tube do you have used?
Just search "vacuum hydrolysis tube," and search for the size, design, and availability in your location.
Something like this:
https://www.dwk.com/na/kimble-kimax-vac ... lysis-tube
