Breeze 3.3: can methods be copied from earlier installation
Hello everyone,
A very simple question ... can we copy methods from one installation to another installation of Breeze 3.3? Actually what we did was that we backed-up the entire Breeze folder from C drive and then did a fresh installation (Format -> WinXP -> SP3 -> Breeze).
Now can we copy methods from the earlier installation to the fresh one? In case someone needs to know our basic system comprises of 2487 detector, 1525 pump and an oven.
Thanks and best regards,
Tanvir Ahmad,
Islamabad, Pakistan
Make an archive of a project and restore it on the new version. Then you can copy whatever you need to new projects and go with it as long as versioning of most things is the same (or close enough).
That's the "Empower" answer. If Breeze is very different, apologies and please ignore this.
In total there are 3 users online :: 2 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
Users browsing this forum: Ahrefs [Bot], Semrush [Bot] and 1 guest
