Air bubble in HPLC Syringe
does anyone have any tips for me on how to avoid air bubbles in my injection syringe? I use water as mobile phase and water as rinsing medium of the autosampler, however, adding acetonitrile disturbed my measurements.
Kind regards :-)
Degassing the water may help.
You may also rinse the syringe with acetonitrile first , then use water .This will clean the inside surface of syringe so reduce the possibility of bubble formation.
Thank you for your reply :-)
Water is already degassed..
How often do you think I should rinse the syringe with ACN?
Logically , before starting a sequence ,but it also depends on the frequency of bubble formation.
Replacing the syringe with a new one, may also help.
Back in university we used to take the plunger out of the syringe, and push it gently on a flat surface with a little rubbing. Make sure the plunger is not tilted. The idea isto make the PTFE seal a little bit thicker. This usually helped for a while but sooner or later they must be replaced.
Good luck!
Jörg
Thank you both for the tips; I will try them next week!
Users browsing this forum: DuckDuckGo [Bot] and 17 guests
