Organic solvent pH / pKa shifts
I've searched the forum archives, and this topic has been covered, but I still don't completely understand, so I'm hoping someone is willing to help me!
I understand that adding alcohols to a buffer system changes the dielectric constant and therefore shifts the pH of the buffer. I have a few questions about this. I'm interested in fluoronated alcohols in particular, e.g. HFIP (hexafluoroisopropanol) and TFE (trifluoroethanol.)
1. Is there a way to measure the pH of the combined system (aqueous buffer + organic solvent)? Can a pH meter be used? Or, is this question irrelevant?
2. If you can know the pH of the organic solvent+buffer solution, and you dissolve a protein or other compound in the solution, do the pKa's of the solute also shift? In other words, will you get different ionization states for the solute in the organic+buffer solution vs. the buffer alone, even if the pH is constant?
I'm looking for references about this topic, or any help anyone can give me. Thanks a lot!
It's *very* relevant, but not amenable to a simple reply. Read these three articles:
http://chromatographyonline.findanalyti ... rticle.pdf
Yes. To oversimplify, when you add organic, the equilibrium shifts in the direction of the less-ionized form.
Thanks so much for the articles. This is exactly what I was looking for!!
