In my work it has not been unusual to have some matrix elements which do not chromatograph correctly under the chosen conditions. If these "humps" are interfering you will have to do some precleaning or multi-step chromatography.
Hi Tim,
Could you tell me the sample solvent you used, always we used the mobile phase as sample solvent. (For using a absolutely organic phase as sample solvent can cause this phenomenon.)
You can try to use less injetion volume to see wether the hump before the main peak is still exist.
In total there are 31 users online :: 0 registered, 0 hidden and 31 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 31 guests
