PAL2/PAL3 rail items compatibility
Does anyone know if 'dumb' stacks, trays, etc. from a PAL2 fit on the rail of a PAL3? We need to use a stack that accommodates 4 deep-well plates, which we use on our PAL2's. It's no longer an option for PAL3's. The only stack option is for 6 deep-well plates, which requires a 120-cm rail, which we don't want to use.
I'll update, in the event someone years from now has the same question.
Nope, rail width, objects orientation is completely different. You cannot use PAL2 rail objects on PAL3.
