Gas chromatography (GC): It is mainly used for the analysis of volatile and semi-volatile organic compounds, especially in environmental monitoring, drug detection, and petrochemical product analysis.
Thin Layer chromatography (TLC) : This is a relatively simple and economical chromatography technique that is often used for rapid analysis and purity detection.
Ion exchange chromatography: It is mainly used for the separation of ionic compounds, such as proteins, nucleic acids and other biological macromolecules.
Affinity chromatography: The use of specific interactions between biomolecules to separate, often used for the purification of enzymes, antibodies and other bioactive substances.
Gel permeation chromatography (GPC): mainly used for the determination of molecular weight distribution of polymer compounds and polymer characterization.
Ultra-high performance liquid chromatography (UHPLC): UHPLC has higher resolution, speed and sensitivity than HPLC.
Capillary electrophoresis (CE): Although not chromatography in the traditional sense, it is also an analytical technique that uses electric field forces to separate, and is sometimes classified as one of the chromatographic techniques.
--https://www.creativebiomart.net/chromatography.htm
