NMR
Discussions about methods, troubleshooting and best practices across both pharmaceutical and biopharmaceutical analysis.
NMR
For NMR, what are the potential negative effects of being close to it when it is operating and generating a strong magnetic field?
Also, are NMRs mostly in the form of a desktop instrument or a big drum type apparatus
Don't magnetic fields fall off very quickly with distance? Inverse cubed or something?
Most of the newer ones are very well shielded so the 5 Gauss line is only a few inches from it. That is for the high field (~500 MHz). The desktop ones I am not too familiar with but they don't require cryogens.
