another MS interpretation
Hi all, while I wait for results on the molecular ion of the previous mystery molecule, and a gap in the schedule to set up CI, here is another "no hits" mystery.
https://drive.google.com/file/d/12YNyeM ... drive_link
https://drive.google.com/file/d/1hqZEQN ... drive_link
EI, Bruker Scion single quad, with a retention index of about 1785 on a 60m wax column. The peak is pure.
There are tiny peaks at 73, 74 and 75 that are from the compound.
This is a substantial component of lion urine, extracted with methanol.
Thanks in advance.
Peter,
Very little to work with here, but some thoughts
m/z 43……..CH3CO+ (ester); C3H7+ (alkyl chain)
by extension m/z 57……CH3CH2CO+; C4H9+
According to McLafferty’s book, m/z 43, 57, 71 due to loss of —-NR—CO— from carbamates and cyclic amides.
If m/z 75 is molecular ion, then NO halogen / phenyl
but N = odd count (1, 3, 5 etc).
As with the previous mystery molecule, we badly need a Mol. Wt., so I look forward to any CI results.
JMB
Thank you, JMB
I will get the CI set up as soon as I have a chance.
I will also run it on the PFPD.
Users browsing this forum: Bing [Bot], Semrush [Bot] and 8 guests
