How long do i need to use the syringe for ?
Hi i have hplc syringe , how long do i need to use it because right now i have use it for one year ?
how much is the hplc autsampler because i want to buy one as i am phd student my department has not one , or do you think manual injection for all my period is ok ?
i need also column how much is it and can i hire one ?
thanks
sharookh
Manual syringes are good until bent, clogged or contaminated beyond your cleaning capabilities.
Autosamplers start at ~$12,000-$15,000. Your need is a function of how many injections you need made, how long your typical run time is and how many samples you can prepare in a day (assuming they're fairly stable).
You buy (not rent) columns, they're typically $400-$600 for what is now a "standard jacket" 150x4.6mm 3-5µ C-18 column of good quality.
thanks indeed for you Dr.
it too expensive :roll:
