high resolution mass determination
should I isolate compound or just use lc column. which one will give me more accurate mass. thanks.
I would expect the accuracy of the mass to depend on the instrument used, the mass calibration, the stability of a reference mass signal and the signal strength for your unknown. What are the differences between running the compound on the LC and isolating the compound?
I know that my question probably is silly but I just want to know what is the "general rule" to do HRMS. but it seems there is no such a general rule.
as i understand, pure analyte with pump syring could well control signal strength and less interference, which will guarantee more mass accuracy. but it is also very time consuming.
In total there are 33 users online :: 0 registered, 0 hidden and 33 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 33 guests
