high resolution mass determination
should I isolate compound or just use lc column. which one will give me more accurate mass. thanks.
I would expect the accuracy of the mass to depend on the instrument used, the mass calibration, the stability of a reference mass signal and the signal strength for your unknown. What are the differences between running the compound on the LC and isolating the compound?
I know that my question probably is silly but I just want to know what is the "general rule" to do HRMS. but it seems there is no such a general rule.
as i understand, pure analyte with pump syring could well control signal strength and less interference, which will guarantee more mass accuracy. but it is also very time consuming.
Users browsing this forum: Google [Bot], Semrush [Bot] and 4 guests
