EPC calibration GC6890
Hi people!
I work at GC6890.
Did anybody calibrate the EPC pressure sensors? When & How is that necessary?
Best regards
Agilent calibrates them at the factory prior to delivery.
Jumpshooter
Yes, but I refer to The Zero pressure sensors.
Yes, but I refer to pressure sensors zero.
There should be a produre that can be used to calibrate the zero point and offset, these are the settings that most often need adjustment. Check the Agilent web site to see if the procedure is posted.
