Problem with 7376B autosampler
Hi every one. 5972/5890II plus/7376B system and chemstation G1701BA Ver B0.10. After running a sequence the run gos to preinjection and then to injecting but the GC would not do any thing. Also the autosampler arm would not take back the sample to the tray after the injection. Any help
Are you getting any error codes (flashing lights) from the injector tower or controller?
[quote="Russ"]Are you getting any error codes (flashing lights) from the injector tower or controller?[ No just the GC want go to run mode and the green and the red light is not even flushing it is like A DEAD GC]
I can't be much help here as I am not familiar with Chemstation, but is there a post sequence option set as part of your sequence?
Users browsing this forum: DuckDuckGo [Bot] and 3 guests
