Empty glass HPLC column, 2.1 mm ID
Hi all,
does anyone of you know where to look for an empty glass HPLC column with 2.1 mm ID? I found only 100 x 3.0 mm column (ChromSep), however I am looking for smaller one.
Thank you
J.
HPLC 2017 in Prague, http://hplc2017-prague.org/
SGE sells glass lined tubing. It is stainless steel tubing lined with borosilcate glass.
http://www.sge.com/products/glass-lined-tubing-glt3
I quote:
"Connections: The use of graphite ferrules is recommended for connecting GLT™. Swagelok® metal ferrules may only be used with 2 and 3mm ID 1/4" OD, and 1.5mm ID and under 1/8" OD GLT™. Use of Swaglok® ferrules with larger ID GLT™ may result in cracking of the glass liner."
Maybe that'll work for you.
Best regards,
Robert
Robert Haefele
Thank you Robert,
I will check it out
J.
Hi Jiri,
If not a secret why glass?
We machine threads into our SGE glasslined tubing, so the concern over ferrules is a nonissue. For that matter, SGE sells threaded columns of the material themselves.
PolyLC Inc.
(410) 992-5400
aalpert@polylc.com
Hi Jiri,
I want to prepare monolith in larger ID than usually and to hold the monolith inside the inner wall of the tubing/capillary/column needs to be modified. I have ordered peek tubing, but to check also other possibility I am still searching for a glass tubing.
Users browsing this forum: Bing [Bot] and 18 guests
