monitor quant ions EPA 524.2 surrogates istds ccc
Hello!
Anyone out there have any suggestions how to be compliant with EPA 524.2 section 9.4 that requires the the quant ions to be monitored for internal standards surrogates, etc in samples. I am using ChemStation wiht Enviroquant 1701AA version. Is there some feature that can be utilized to tabulate these ions within a sequence? How is everyone out there doing this? Any help is MUCH APPRECIATED! THANKS!!!
Better Living Through Chemistry...
I use a custom report.
I can't seem to paste a copy of what I use. If I had your e-mail I can send what I use.
I use a Method Database and cut and paste into an Excel spreadsheet. It took and hour or so to set up but only takes a few minutes now to process and print a form.
The database function allows plots and control charts which you should not tell your QA people about. Otherwise it is a special type of custom report.
THANKS BigBear and STEVE. BigBear how can I send you my email address???
Steve: Any idea if the database is part of EnviroQuant? THANKS!
I don't know other than posting it here.
The database function is loaded from the custom reports menu. If it doesn't appear on that menu, you don't have it.
Sorry, I don't have a 1701AA version with Environquant to check to see if it is there.
