ChemStation report size in pdf
I'm using ChemStation A.10.02 and I'm trying to print my reports using Adobe pdf. The reports appear very small and I need to find a way to print these report files in normal size.
Very strange. Just checked with my A.10.02. Normal size pdf reports are generated.
I guess the problem is with pdf printer driver.
I use pdfCreator (as I remember well with default settings).
Before printing to pdf I select pdf creator as specific printer.
Maybe you should check settings of your pdf printer.
Thanks. The problem was with the pdf printer.
