Easychrom Elite
Does anyone know how to configure the Easychrom Elite data system to make it possible to see the chromatographic signal in real time (not the online signal) while a sample is being analyzed.
Javier Molina
CIAD, AC
if you i understand correctly, you want to see past results while the system is running and not only the current run,
then you need to open a parallel off-line. for beginners this is very confusing at first you will see,
do - right click, open off-line
simply open the sequence data files and method in the off-line and you can then do re-integrations
Than you for your advise.
What I was not being able to do was watching the chromatogram in real time.
I could fix that by selecting the external triger mode to be able to perform manual injections and see the run chromatogram.
Javier Molina
CIAD, AC
