Macro to Export Signal (Time, Response) to CSV file
Hi dears, I need a macro line(s) that could export the current channel file (Signal) to CSV file. Thanks in advance
HAMA
Without more details, you will not get much of an answer.
That said, most chromatography data systems (CDS) include a provision for exporting raw data into CSV format. If it comes out as a single column of numbers, you need only look up the sampling rate for the injection and you can easily make a companion column for elapsed time, in seconds.
Dear DR
Thank you very much for your reply. I could generate the CSV file from the export menu but I was hoping to have a command line that I could insert in my macro. The macro will be used to generate all the files included in my project directory (more than 100 Channel files). Thanks again for your earlier reply.
Hossam
HAMA
Others may have experience with this sort of thing - if you provide at least the name of your data system, the appropriate persons may chime in.
If you do a search on this forum for 'CSV', you will find a macro that I supplied to an earlier posting that should do what you what to do.
Gasman
Dear Gasman
Thank you very much. it work very fine.
Thanks again
HAMA
Users browsing this forum: DuckDuckGo [Bot] and 4 guests
