5972 Transfer Line Thread Size
I found a die that will clean the brass from the threads on a 5972 transfer line where the column connects. It is size 10NF32.
Size 10 with 32 threads per inch die should be available at your friendly Ace Hardware !!!I found a die that will clean the brass from the threads on a 5972 transfer line where the column connects. It is size 10NF32.
By the way, for size 10 threads, 32 is fine, and 24 threads per inch is regular.
