Alternative to Glycine buffer (pH 9.0)
13 posts Page 1 of 1
Hi all,
I'm searching for glycine buffer alternative for mobile phase.
I'm using gradient method : sol.A Glycine buffer (pH 9.0), sol.B : Acetonityl:MeOH 85:15.
I'm searching appropriate buffer at pH 9.0 for UPLC system (but not Ammonium based).
Please help :P
Does it need to be volatile? If not, how about Tris?
No, it doesn't have to be volatile.
What about phosphate buffer, prepared from tri-basic and di basic phosphate?
It should work as the pka's are 7.2 and 12.32, barely within the +/- 2 "rule".
Another organic buffer is CAPSO, pKa 9,7.
Or 1-Methyl-piperidine
Or Borate, but it is not volatile.
Hellow
Volature basic buffer
1) ammonia buffer (NH3/+H20/+ NH4CL) or NH3/+H20/+ (NH3)2CO3
This russian langvige , but text scool task understood without translation
http://forum.xumuk.ru/index.php?showtopic=72307
2) triethylamine buffer (C2H5)3N+H20 + CH3COOH
Borate buffer -good stabile buffer , but in LC-MS borate buffer must not use.
can you say why not ammonium based buffer?
Nasty (Ungly) it is.
Volatile, malodorous, unstable and RP-silica gel "eats". But because of volatile buffers for UPLS-MS the ammonium is most volatile.
2 solntzevorot (Midsummer)=> by nick can be seen from the "brozer slavjans". Come on (part of) on anchem.ru
Am I going bananas or did solntzevorot say his buffer need not be volatile?
Hello HW Mueller.
Very likely when you worked with the ammonia buffer and know that "it's not sugar". :D
Thanks to all for the replies.
The buffer no need to be volatile.
Whith ammonium buffers (at least with those I have in the lab) I experienced with to much system peaks in the UPLC system.
to DSP007 : thanks for the link, I freely speak Russian and Ukrainian. (Born in USSR :) )
You shouldn't experience system peaks with ammonium buffers. If you saw peaks is probably either the low purity or contaminated salt. I would try again with some new high purity container.
