Sudan Dye in Chilies
Hello Everyone,
First of all, thank you all for your experience and advice! I am a frequent viewer of the forum, this is my first post.
Does anyone know of a HPLC method for the determination of Sudan I, II, III, and IV dye in chilie products? I have found a few methods for Sudan I.
I have both a Diode Array and a Fluorescence Detector.
I am also interested in column recomendations for this analysis. I currently have a YMC-ODS-AQ, Synergy Hydro RP, YMC-Pack Polyamine II, and a Zorbax-C8.
Any suggestions or reccomendations appreciated.
Lynda
A standard reversed-phase column will be fine. I would start off with a gradient with phosphate around pH 2.5 and inject the 4 dye standards. You will find your peaks in a gradient from 5 % to 95 % acetonitrile. Once you know where the peaks elute, you can start the gradient with a higher organci composition etc. Next, you need to get the dyes out of the chili. You need to think about an extraction procedure.
I did Sudan I, II, III just for show one time. They are surprisingly hydrophobic. I used 50:50:0.5 MeOH:MeCN:AcOH on a 150mm C18 column, and they eluted between 3 and 6 minutes. (That eluent is useful for phenolic antioxidants, and I had some made up, so...)
As for the chili peppers, they have a nice assortment of pigments that are likely to get in the way. You will need your diode array.
Mark Tracy
Senior Chemist
Dionex Corp.
Uwe and Mark,
Thanks for the response. I will use both your info in my method development!
Lynda
In total there are 16 users online :: 2 registered, 0 hidden and 14 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], John Guajardo and 14 guests
