Separation of Na salt of p- Cresol with p- cresol
Hellow every body,
I want to separate Sodium salt of p cresol & P cresol. Is it possible with derivatization by chloroacetyl chloride??? If no then what is the suitable derivatization agent.
Best regards
Praveen
My thought would be to partition the analytical mixture between mild, aqueous acid and an organic solvent (like toluene) and then derivatize to ensure the presence of salts does not cause a problem. I tend to like MSTFA as a reagent for phenols, catechols, and such, but chloroacetyl chloride will probably work - I would add some dry pyridine remove the acid from the reaction.
One will shift equilibrium with the partition, in the other chain on this the answer was given , I think by Vlad.
Reading this question first in the GC questions, I read the question as sepration of both compunds from matrix rather than from each other. The sodium salt will not be seen in the GC - at least as the sodium salt. I gave an answer that wouild separate the cresol and cresol salt from other things in the matrix...
