TurboVap II error codes
Of course , I can't find the manual. I am getting an error code upon startup with continual beeping. The code is 5t. Can't find anything on a google search. The unit is about 10 yrs old. Thanks.
I recommend contacting Biotage. They now manufacture this equipment.
Don Shelly
Don Shelly Consulting, LLC
Could your code be St? That is when the desired temp is above that allowed when sensors are installed ( 60c).
That was it, someone changed the bath set temp to 70C. Thank you for your help!
Glad I could help.
Users browsing this forum: Ahrefs [Bot] and 13 guests
