Perkin Elmer error codes
Hi all.
Not sure if this is a FAQ or previously asked, but it didn't appear so in a key terms search.
I have a couple of Perkin Elmer error codes appearing (time to time) and usually self diagnose and fix. However, to speed things up, is there a published table of PE error codes anywhere?
I haven't come across any the usual publish domains, guide, specs or web searches.
Many thanks.
AlStav
Have you see on the totalchrome user guide?
Nothing noted.
Had a look through, nothing relating to the error codes seen (or my skim reading is skimming too fast).
If you don't found nothing, you ask directly to your Technical if he have what you search... or not?
