Can anyone advise on the following issues?
1 post
On a CN column, running with 60:40 Water:MeOH with 0.05% TFA, samples prepared on 50 mM phosphate buffer (pH=6.
, containing SDS were injected. Apart from the fact that retention times are dependant on the concentration of SDS present (presumably because the peaks belong to cations), a downward step is observed in the baseline. It’s been observed that the higher the concentration of SDS is, the earlier this step occurs.
1 post
In total there are 19 users online :: 2 registered, 0 hidden and 17 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot], John Guajardo and 17 guests
