Missing points in the Galaxie Calibration Curve
I am using the Galaxie Data System with the Varian 3800 GC. When I try to set up a seven point calibration all that I see in the calibration curve is only one point - the last point in the level. Anyone know what needs to be done to display all seven points? :(
Sounds like you are using the "clear all points" setting when you're doing your calibration. This would explain why you are only seeing the most recent calibration point. Change "Clear all points" to "add" and see how it goes.
Rich
"Can't be king of the world
if you're slave to the grind"
HI,
are you clicking on Level 1???
Users browsing this forum: DuckDuckGo [Bot] and 2 guests
